Exterior concrete foundation from ground up to siding
Old 05-14-04, 11:10 AM
D
My concrete foundation walls (exterior) between the ground up to where the siding begins (is there a name for this??) has some detrioration all way around house. There was/is also some type of stucco or some apllication, thicker than paint which has mostly fallen off, covers maybe 30%, some loose, some not. Where it is bare, the concrete is kind of rough and aggregate exposed. A few of the corners also have some concrete broken off a bit more deeply.
I would like to repair and then paint this or whatever is appropriate to make it look nice. How should I proceed?
Old 05-15-04, 09:41 AM
C
After removing the failing stucco, you might be able to use this technique to smooth the walls for painting.
http://www.quikrete.com/diy/ResurfacingConcrete.html
Hope this helps.
