Repair concrete steps leading down to basement
Old 06-07-04, 09:15 AM
jenniferii_98
I am a new homeowner who knows NOTHING about home repairs. My problem is that I have a walk up basement with concrete steps that are leaking and flooding my basement when a heavy downpours occurs. I have found a crack at the top of the steps. I used my water hose and find out that steps leak in about 3 places when water pools at the top of the steps (actually on the ground next to the steps). I am needing any information as to how to fix the existing steps without having to replace them entirely. There is a drain at the bottom of the steps which I had snaked out today which will solve the problem with the flooding in my basement, but I need to correct problem with steps and the walls.
Old 06-07-04, 07:59 PM
C
Direct the water away, and regrade to prevent its collection here. This will solve the problem the same way as any other by removing the source of the problem: the standing water.
Hope this helps.
Old 06-08-04, 09:51 AM
jenniferii_98
My entire back yard slopes down hill. My house is built on the side of a hill.
Old 06-09-04, 09:49 PM
C
The slope should make the drainage solution simple, then.
