Need some help identifying this process
Old 06-17-04, 09:23 AM
Jano33
Hi all, first post. Glad I found this forum!
I am trying to identify a technique for brick finishing and am coming up with deadends. It is essentially a simple brick and mortor installation where the mortar is set flush to the brick surface and then the entire wall is coated with a light wash of mortar.
It gives you a somwhat smooth surface in which you can see some of the brick and mortar joint texture through the "wash" coat of mortar. Here is a picture. [URL=http://home.comcast.net/~mjanowak111/archive015.JPG[/URL]
I have not been able to identify the technique and it is somewhat new to our area (Michigan), or at least as far as I can tell. We plan to use this on our home that is starting construction very soon.
Old 06-17-04, 09:25 AM
Jano33
BTW, it may not look like the surface of that house is smooth, but it most certainly is. I walked right up to it and touched it.
