Concrete Basketball Court Help
I am planning on installing a concrete basketball court in my back yard. I have pretty much decided on a pad about 20X30. I would like to avoid any bumps in the surface (ie expnasion joints) but also do not want to have it cracking on me. I know when I see the courts in the park they do not have theses joints. Any ideas how to prevent cracking? Also how thick? I most likely will never drive on it with any vehicle. Thanks for your help.
In order to pour a pad that is guaranteed to not crack you must mix the correct additives into the mix. Where do you live? Ask your readymix plant if they have any Aquaron products. There are many many reasons a pad will crack, if you are not a "concrete expert" then I would not recommend tackling this project alone, instead contact a "decorative concrete" person in your area, they should be able to pour a pad that is guaranteed to not crack.
