Any experience with those $300 3.5 cubic ft cement mixers?
Old 07-19-04, 09:23 AM
MrE_Dog
I'm planning on buying a plastic tub 3.5 cu ft cement mixers. They range from $200 to $300.
1. How well do they work?
I'm planning on making a backyard patio with permanent 2x4 forms/borders. I'd have to pour 5 80# bags into 16 rectangles. This is roughly 150 sq ft. I should probably rent but I don't have the time or the man power to do it in one to two days. I figure that if I had my own mixer, I could do it over a couple of weekends.
2. How fast could I mix 5 80# bags in a 3.5 cu ft mixer?
3. If I made 9 sq ft rectangles at 4 inches thick, do I still need rebar? I hope not.
Thanks for any help!
Old 07-19-04, 10:01 AM
C
They would fit in one load. 5x.666cf=3.333cf, all other things being equal.
If they don't support a load, probably not.
Hope this helps.
Old 07-19-04, 07:51 PM
E_Dog
I just bought one of those $249 mixers at Lowe's and I'm using it to mix mortar for adding a couple of extra courses to my block walls.
So far it works pretty well. It's not as good as a big old gas-driven one, but it does the job.
Max capacity seems to be about two 94# bags before it starts to struggle.
HTH
Matt
