Best tool for grinding out existing mortar
I recently purchased a brick home and it needs a lot of tuck pointing done. I would like to tackle the task myself. The first thing I would like to do is grind out the mortar that is in the areas that are breaking apart.
What kind of tool would I need to do this and where would I find something like this? I am assuming some kind of diamond bit drill, but I have no idea what to call it.
Also, would I be better off using S type mortar mix to fill in the areas I grind out, or would the tuck pointing that comes in caulking style tubes work just as well?
A 4" 1\2 Angle Grinder with a Diamond Disk would work like a Charm. If you look around try and find a Commercial| Builders Supply they will carry Tuck Pointing Diamond disk. These are disk that are wider then a normal disk and can take out a Joint in one pass. The Home Center will have regular 4" Diamond Disks they work well, you will have to make a few passes with this Blade. There is also a Chisel called a "Plugging Chisel" it is designed to chip out Mortar.
Type "S" Mortar would be the way to go.
You will want a few tools a Tuck Pointer and a Brick Trowel. The Tool to finish the Joints will depend on how the other Joints look at this time. Here is a How to on Tuck pointing.
http://www.quikrete.com/diy/ReplacingDamagedBrick.html
