Mortar stains on paving stones
Anyone know of a successful method to remove mortar stains on paving stones?
I tried an acid solution, which worked, but was VERY labor intensive...is this my only solution?
Thanks in advance.
Jrexi
Thanks in advance.
Jrexi
Yes it can be alot of work to clean Masonry. A Masonry cleaner or a Muratic Acid solution is what is used. Some people use a Power Washer you will have to be careful not to remove to much of the Mortar Joint. You can also scar the Stone Work if you're not careful.
When using a cleaner wet the surface and use a scraper to remove as much of the material as you can, then apply the Cleaner you may have to scrap some more , then brush it with a Scrub Brush. Rinse thoroughly. A repeat may be needed.
JRexi, did you ever figure out how to clean those pavers? I'm having the exact same problem. I tried muriatic acid, and it doesn't do the trick, even at stronger than the recommended solution. Sandpaper (reciprocating sander) works OK and is easy, but doesn't get the mortar stains out from all the pores of the pavers. My next step is going to be to purchase an axle grinder and literally grind the pavers down until all the mortar stains have been ground off. But I'm afraid of doing serious damage to the pavers by gouging and scarring them.
-Diggity
-Diggity
