Adding to existing cement slab
Old 09-08-04, 06:37 PM
Mom2Z
Question Adding to existing cement slab
I have a cement slab in my yard that is 6'11" x 10'4" and I'd like to widen it to at least 8 feet to accomodate a new shed that is 8 x 10. What is the best way to do this? Should I frame it out and add more concrete? Should I use pavers built up to be level with the slab?
I plan on being in this house a long time and want something that is sturdy and will last, but I have NO clue how to lay cement? Any info you can give me, or websites you can direct me to would be great!
Thanks,
Catey
Old 09-08-04, 07:14 PM
C
If you want it to last, dig out and frame for a 4 inch slab and tie the rebar to the existing slab by drilling into the existing slab.
Here is a description of this sort of project from the perspective of laying a single slab.
http://www.quikrete.com/diy/Concrete...mallSlabs.html
More information:
http://www.doityourself.com/concrete/patiosteps.htm
Be sure to check with the local building authorities to see if a permit is required for this sort of work in your locale.
The small size you have in mind won't take more than about 5 cubic feet of concrete.
Hope this helps.
