hollow cement floor in basement.....
hollow corner in basement.....
I built a house last year and I am now ready to put my laminate flooring in my second lever family room(split level house). One of corners under the floors outside wall has settled a little and has a hollow sound to it. Its about 3'x3' pie shaped from the corner.
My question is...should I ...
a) leave the cement alone and floor over it since I probably wont be putting anything heavy there and hope it doesnt crack.
b) drill a hole big enough to pour some sacrete in there to fix the problem
c) rent a cement saw, cut a section out, re-cement the 3 feet and go on?
thanks in advance for any help.
Do you have a footer drain and a sump pump down there? It sounds like you may have a water problem( perhaps the drain tile not pitched properly) where the gravel has washed away.
If it's just a case of settling I would live with it since it's in the corner.
Yes...there is drain tile all the way around the house. I haven't had a water issue yet....just some natural settling(1 year old house). I figure since I'm doing a pergo floor I can just replace the area if there is ever a problem but I just needed a second opinion.
thanks for your input
