Concrete splatter on brick
Old 09-10-04, 02:07 PM
D
I had a patio installed and when they finished there was splatter on the brick. I have tried pressure washing to remove the cement, but its not workding.
Could anyone recommend something that will remove the concrete?
Thanks
Jim
Old 09-10-04, 09:14 PM
T
What you will have to do is remove as much as possible with a stiff sharp scraper. A Painters 5 in 1 tool works well. Wet the surface and just get busy using some elbow grease. Once the bulk of the Concrete is removed an Acid was should get rid of the Stains. Here is page on Acid cleaning Bricks.
http://doityourself.com/brick/specialwetsystems.htm
Just remove as much as possible with the scraper before you Acid wash.
Old 10-01-04, 12:19 PM
D
Thanks for the help, its greatly appreciated. Kodos to you.
