Building Wood Steps Over Cement Ones
Old 09-12-04, 01:19 PM
cement head
Question Building Wood Steps Over Cement Ones
HELP!
Can wood be used over cement steps [ steps need major repair on corners]
How would this be done? Lag bolts?
ANY ideas or help woould be appreciated.
Has anyone tried this yet?
Thanks much,
cement head
PS
Any thoughts on why this WOULDN't work?
Old 09-12-04, 02:03 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You dont say how wide they are. Put a new riser on each side of the old steps and work from there . Use P/T wood for all of it .
ED
Old 09-13-04, 02:46 PM
H
Wood over cement
Originally Posted by cement head
HELP!
Thanks much,
cement head
PS
Can't be done.
Adding any dimension of wood over already existing concrete or masonry steps will alter the code required riser heights and possibly the depths of the treads, make them a fall hazard, and potentially illegal against under acceptable building codes.
Repair or replace the masonry steps asap.
