Drilling a Hole in Brick
Old 09-21-04, 04:23 AM
G
I need to run a new sump pump drain line out if the house. The first thing I want to make sure I do correctly is punch a hole through the brick. I also need to go through the wood bond (2x12) behind the brick which is resting on the top of the basement wall.
I'll be running 1 1/2" PCV. What tool(s) would you recommend to make this a clean job? I want to avoid disturbing any of the neighboring mortar joints. Thanks!!!
Old 09-21-04, 04:54 AM
fewalt's Avatar
Well, a 2 inch masonry bit(hammer drill) would work great, but that's probably not gonna happen.
I'd use a chisel and knock (break a brick in half), then use a hole saw for the wood. When the pipe is in place just mortar up the entire hole.
fred
Old 09-21-04, 07:19 AM
G
Thanks for the reply.
I have a 1/2 Milwaukee hammer drill. Is there a 2" masonry drill bit available? I had no idea! Wonder what the cost is?
The more I think about this, I wonder if I could use a small 3/8" bit and drill several small holes around the finished diameter of the hole and then knock it out with the chisel?
Old 09-21-04, 06:57 PM
fewalt's Avatar
Check at a rental store for the 2" masonry bit. Purchasing would be big bucks for one time use.
The multi-hole circular pattern has been suggested here in the past.
fred
