90 degree corners
Old 09-21-04, 06:46 AM
ddownin
Question 90 degree corners
my husband is building a dry lock retaining wall using anchor system blocks.he is building it with 2 90 degree corners and he is having a terrible time with the 90 degree corners.he has cut the blocks both ways in half-long ways and across the middle,but the blocks don't seem to overlap seams like they are suppose to.does anybody know a way to do the 90 degree corners?
Old 09-21-04, 08:38 PM
Frank99's Avatar
The Wall System He is using might have corners avaiable.
Some walls the blocks are only used in straight runs only and are not made to be cut up for corners.
Good Luck Frank
