Sidewalk mortar joint repair
Old 09-29-04, 01:47 PM
kdkrone
I have a brick sidewalk that was installed 12-14 years ago with a dry cement/sand mix that was then wetted down. A number of joints have deteriorated, perhaps aided by moss growing in them, and they are in need of repair before the winter.
I would like to repair the joints that have developed holes but I do not know the ins and outs of masonry. My thought is to pressure wash the joints, then purchase some mortar mix (Spec Mix has been recommended). I will fill the holes, then level the mortar with a trowel (which type? a thin rectangular one?). It is my understanding that to remove the white mortar that is left that I use acid. What kind and at what strength? How long do I leave it on? Do I wash the whole sidewalk (bricks and mortar) or just the bricks, attempting to keep the acid off of the mortar? How long do I allow the mortar to dry before I do an acid wash?
If there is a website that might be helpful, I would be grateful.
Thanks
Ken K
Old 09-29-04, 03:32 PM
C
Here is a site that can cover your project. More than one of the links in the repair section is needed to cover it all, so I posted the whole page for you to review.
http://www.quikrete.com/diy/searchprojects.asp
Hope this helps.
Old 09-30-04, 12:34 AM
kdkrone
Thanks for the post. If I choose to use a mortar mix to fix the problem, should I use a bonding glue? Or are Quikrete solutions the best solutions? I am not sure if I can find the product in my area but I will call their customer service...
Thanks
Ken K
