brass eagle on brick house
Old 12-15-04, 09:28 AM
tammy0
My husband and I just got this brass eagle:
The eagle is 15" wide and 10" high and weighs approximately
6 lbs.
My question is how would we go about hanging this on the outside
of our brick house.
Last edited by Annette; 12-15-04 at 09:59 AM. Reason: took out web link & company name - not relevant to question
Old 12-15-04, 10:02 AM
Annette's Avatar
Arrow Moved from Decorating topic
Welcome to DIY.com and thanks for your question! i've moved your post into the Bricks & Masonry topic, where they'll be able to help you with your question!
good luck!
P.S. your picture was lost, because the vB codes are Off in this topic - sorry! even without it, they'll still be able to help you!
Old 12-15-04, 06:04 PM
P
Received 2,231 Upvotes on 1,990 Posts
A masonry nail driven into the mortar joint should hold it. Better yet you can drill a hole in the mortar joint, insert a plastic molly and run a screw in leaving enough protruding to hang your brass.
Old 12-28-04, 11:47 AM
tammy0
Thanks
I went to a value home center store and got everything you said. I know I would have gotten the wrong bit. Thanks
