sealing window in wall
Old 12-20-04, 12:27 AM
shalsd
Hi,
I have a window in the middle of my wall which i need to seal. What would be the best way to do this? One contractor suggested using a wooden plank and then waterproofing on the exterior while another suggests waterproofing and using bricks to seal the hole. Any ideas as to which would be the best way to prevent cracks and water leakages on the internal walls?
thanks,
confused
Old 12-20-04, 07:49 AM
C
Do you want to seal leaks in and around the window or close the opening in which the window is installed?
