question about a concrete block.
how much weight can be held by an 8x8x16 2 core concrete block?
where did you get the info? going mad looking for this on the web...
thanks.
thanks.
The most common Blocks comply with A.S.T.M. C-90 standard . Here is some info on this.
http://www.masonryinstitute.com/guid...od_b-p3-4.html
One thing you have to consider this is for when used correctly with equal pressure on all 4 sides of the top of the block. A block on its sides is not strong at all.
