chimney brick cleaning
Old 01-17-05, 03:49 PM
rmt
Smile chimney brick cleaning
The outside of our country farm home is composed of a beige brick. The chimney stack has had the creosote from the inside, leach out to stain the outside of the bricks in black. Does anyone have a tried cleaning solution for this problem? Thanking you in advance, for responding.
Old 01-17-05, 03:52 PM
T
Received 2 Upvotes on 2 Posts
There are commercial masonry soot cleaners available. If soot is causing a problem, then you need to have your chimney inspected and cleaned by a professional chimney cleaner. Soot should not be leaching out to stain exterior brick. A chimney cleaning and inspection is in order.
