painting or staining brick
Old 02-22-05, 08:52 PM
L
I saw a landscaping program on one of these tv shows and they painted or stained the underpinning brick of a house. I did not however, see what they used to do it with. I have a very pale shade of brick that that underpins our home. We just painted the masonite structure and put on a new roof and the brick just doesn't do much for it. Anything that would help darken this and give it some richness would be great.
Old 02-22-05, 10:01 PM
C
Here is some information on painting brick.
Should I paint my brick wall?
A brick wall may be painted provided the correct preparation is done, the proper paint is selected, and the paint is applied correctly. Generally, new brick walls are not painted. However, if you desire to paint a recently constructed brick wall, it should be allowed to fully cure 28 days and should not be cleaned or treated with acid solutions. Alkali-resistant paints should be used and a zinc chloride or zinc sulfate solution may need to be applied to the wall to neutralize the surface.
Painting brick does not preclude good construction and detailing practices. Any deficiencies such as surface deposits; broken brick; cracked, loose or missing mortar; or inadequate flashing and weep holes should be corrected prior to painting. In addition, the brick should be thoroughly cleaned and given ample time to dry before application of paint.
For brickwork to function properly, the wall must resist moisture penetration and be permeable to vapor from the structure. Consequently, any paint applied to the wall must also have these same characteristics. In addition, the inherent features of a brick wall which channel water out, such as weep holes and vents, must not be clogged by paint or caulk to inhibit the flow of water.
Latex and portland cement-based paints perform well on brick walls. Oil-based, alkyd, rubber and epoxy paints do not allow any vapor in the wall to escape and consequently should not be applied to brick. Prior to painting, the brick should receive a prime coat suitable for the paint application per manufacturer's instructions. From:
http://doityourself.com/brick/brickfaqs.htm
Hope this helps.
