Building a Brick Arch
Old 03-02-05, 05:03 AM
H
Can anyone suggest a good book or other resource on constructing a brick arch? Specifically, I'd like to build a segmented arch. I am competent at basic masonry, but have never attempted anything quite like this. Thanks in advance!
Old 03-03-05, 04:52 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
can you give size of opening"
usually you cut the arch out of plywood and make a frame and install it below the brick line and then place your brick over it.
cheers
pg
Old 03-03-05, 06:40 AM
H
Thanks for the reply. I've pretty much got that part understood, but I was looking for a step by step, how-to... mebbe with pictures (I like pictures). Or maybe I should just bite the bullet and attack the project already! The arch will be approx 6ft.
Thanks!
Old 03-07-05, 05:20 AM
pgtek's Avatar
pic
hi
check this link
shows step by step but uou need to ajust to your opening
they show how to make the arch
cut out the patern and when tou have it place in the opening use 2x4 or 2x6 to suppert it at each end like a jack stud.
cheers
pg
http://mha-net.org/msb/html/bakeov16.htm
Old 03-07-05, 09:25 AM
H
Hey, that's a pretty good link. The archwork is nice. I also found a really good book on the subject with great step-by-step instructions (and pictures!). It's from the Black & Decker library called "The Complete Guide to Home Masonry".
Thanks for the assistance
-Hudzo
