Retro-ing a "Rat Slab"
Old 03-03-05, 12:45 PM
jmazur
hey all...
i have a circa 1938 cottage style home, with 3/4 basement the other 1/4 is unfinished crawlspace, approximately 200 square feet.
being that the house is under total renovation, i figured now would be the best time to address this issue.
i'd like to pour a 4" *rat slab* which would require approx. 2.8 c/u of redi mix.
i'm trying to find out what exactly is recommended under the pour?
my initial ponderings have me thinking something along these lines:
6 mil vapor barrier
gravel
reinforcing web
mix
i'm also wondering how i would level it being that there would be no *removable* forms?
any feedback would be greatly appreciated.
thanks much,
--j
Old 03-03-05, 07:54 PM
C
If the dirt is undisturbed and this is just for the crawl space, not a basement floor. Gravel would be easy to rake smooth, then lay 6 mil polyethylene, 6 inch wire, then pour the concrete. Here is a link to a video that shows leveling concrete without having forms to bridge with a screed. http://************/3je5a
Hope this helps.
Old 03-03-05, 10:52 PM
Frank99's Avatar
You can also install sreed boards in the middle of the pour about 10' apart this will give you a level to go by, strike off the concrete and imeditley remove the boards and fill it in with concrete, also strike a chalk line along the walls at the correct height.
Old 03-04-05, 06:35 AM
jmazur
Hope this helps.
Yeah, this is *only* a crawl space... the basement part is fine.
I'm not sure what you mean by *undisturbed*.
It is slightly unlevel, so would leveling it *disturb* it?
and also, what kind of gravel would you recommend?
i checked out the link that was great.....
screed boards in the middle just might do the trick for this detail!!
thanks!
Old 03-14-05, 04:52 AM
jmazur
Gravel??
any suggestions on what gravel i should use?
