Stucco repair
Old 03-16-05, 07:06 PM
partst
Question Stucco repair
I just bought a replacement direct vent wall furnace. the old vent hole is about 6" lower than the new unit. Now that I've made a new hole, I have a figure 8 opening in my stucco wall. How do I fill the unwanted area. The plaster on the inside has been removed, so I have access from either side.
Been reading forum for a week or so, and it has been very informative.
Thanks to all the expert help.
Old 03-17-05, 06:32 AM
Frank99's Avatar
What is the wall made of? Is it block, brick, or wood frame with stucco over it?
Old 03-17-05, 06:42 AM
partst
It's a wood framed wall, 2x4 construction. Not much room for backing due to a 1x6 diagonal shear brace right next to hole. Thanks........
Old 03-17-05, 07:36 PM
Frank99's Avatar
Try to fit in a piece of plywood bigger than the hole with tar paper and then wire lath, fasten it on the inside, then go outside and patch the stucco first a scratch coat then a finish coat to match what you have.
Old 03-18-05, 05:36 AM
partst
Thanks, Frank99, Will do just that. I have most materials on hand.
