What type sealer to use around boiler vent pipe?
Old 04-01-05, 09:14 AM
Received 1 Upvote on 1 Post
The vent pipe off my boiler heating system goes directly through my concrete cinderblock foundation straight to the outside of my house. I think it's called a "Direct-Vent system". And then my dryer exhaust pipe also goes straight outside through my concrete foundation. Both of these vent pipes are made of metal I believe and I think they do get hot as well. There is no caulking or sealing either on the inside of the house or the outside of the house for these vents. So I get a cold draft of air coming into the house on the sides of these vents. What SPECIFIC product do I need to use to seal around these vents? I guess I need somethign that can take high heat and also bonds well to concrete to hold the vents in place as well as make it air tight.
I need to run to home depot so if you could let me know specifically what I need that would be very helpful. Thank you!
Old 04-03-05, 07:59 AM
gtm20's Avatar
Same question
I'm glad you asked this. I have the same setup with my direct vent heater and i also need to seal it, i ocassionally get water dripping in.
Old 04-03-05, 08:49 AM
Hellrazor's Avatar
You can buy high temp caulk made for this purpose.
