DIY Brick Work
Old 05-12-05, 01:12 PM
omer
DIY Brick Work
Hello People,
I am thinking of replacing our retaining wall, which is currently some weird wood/bamboo type material, with brick! I have had a couple of estimates from some contractors but it is pretty expensive.
All I need to do is put up a 4foot retaining wall in a semi circle on my front yard. Apparently I don't even need to use concrete since I will not be breaking bricks in to smaller sizes(as done for a porch), and I can just glue them (probably a special brick glue).
It seems to be simple enough, dig a little, level the ground and start placing the bricks making sure to backfill it.
My question is, am I being too ambitious? Or is this doable? Do a lot of people do their own brick work if its for a small project? If so how do you manage the curve when making a semi-circle? Your answers will be much appreciated.
Thank you
Omer
Old 05-12-05, 07:56 PM
C
If you glue or mortar the bricks together, you will need a footer to keep the wall from shifting and breaking apart. If you use the segmented retaining wall blocks that are stacked and offset from front to back, you won't need a footer. These are intended to sit on the leveled ground. Since they are not mortared together, they can shift with the ground.
I don't understand what you mean by bricks broken into smaller pieces such as for a porch.
Four feet is about the limit for a segmented wall without some engineering design. Moreover, some locales require a building permit for walls over a certain height. You might check with your department to see if one is required.
Laying a semi-circle with these blocks is as simple as describing the arc then scraping a place for the bricks.
Hope this helps.
Old 05-13-05, 06:32 AM
omer
Thank you Chris, I will definitely keep the things you mentioned in mind. Yeah the brick cutting was meant for the porch.
I might start this weekend to start getting the material together and perhaps next week building it.
