foundation "flashed"
Old 06-14-05, 01:25 PM
jmazur
not sure if this is the correct term, but i've heard it thrown around by some friends of mine when referring to the smearing (for lack of a better word) of cement along their cmu walkway walls to make it more aesthetic.
the foundation of my cottage is cmu, and i'd like to neaten it up a bit, using this method.
i was looking for some advice / direction.
anything is appreciated.
thanks much,
--j
Old 06-14-05, 08:11 PM
C
This is sometimes referred to as parging, similar to stucco. Here is a how-to on applying this. The loose material must be remove and the surface cleaned first.
http://doityourself.com/concrete/stu...creteblock.htm
Hope this helps.
Old 06-15-05, 04:49 AM
jmazur
yep!
that's it...
thanks so much.
