fence posts
Old 06-21-05, 08:45 AM
dennist 1
fence posts
Am I better off using the quick setting concrete for posts or should I use the regular concrete. Depending on the size of the bag will probably be using 2 bags a hole. Also the posts willl be 5 ft tall. Thanks
Old 06-22-05, 05:54 AM
C
If you need for the concrete to set quickly, then the quick setting variety is needed. Otherwise, I would skip the extra expense.
Old 06-22-05, 12:27 PM
dennist 1
Thanks, Yeah I guess its really more of a expense issue, Those posts shouldnt even move once there set in with a couple of bags a concrete anyhow. Thanks for the reply
Old 06-22-05, 08:09 PM
B
How BIG are these holes? Years ago I put up a split rail fence. Posts were 3 feet in the ground and 5 feet above it. I used less than one bag per hole.
