concrete bolts/screws
i need to secure a 4x4 bracket to an existing cement patio. what would be the best way to do this? and what about a stucco house foundation?
You could drill and set a "hilti" fastener or anchor. This bolt arrangement fits into a hole, the split shell on it keeps it from retracting once the bolt is tightened. The same would apply to the stucco, except that you would have to set the fastener into the material under the stucco.
