Block or wood
Old 07-21-05, 03:00 AM
tom22007
Block or wood
I have concrete block house and would like to add on. It is a spanish style home and will be finishing it with stucco. Would you recommend using block or wood for the addition?
thanks.
Old 07-21-05, 03:46 PM
Received 1 Upvote on 1 Post
Block or wood
I am a great beleiver in compatibility of materials. Wood is organic and wood strucrures are flexible. Masonry is inorganic and rigid.
If you go with a wood addition, it wil shrink somewhat and move differently over time with regard to wind, moisture, ceep and shrinkage.
I would go with an addition built out of the same materials as the original. It minimizes cracks and makes connections easier and more reliable.
Dick
Old 07-25-05, 12:15 PM
tom22007
thanks for the advise. Also, how do I connect the new block wall to the existing corner. Do I just butt the wall up against the existing?
tom22007
