Sealing a basement window
Hi:
We have a 70+ year old home. The basement has a window well in an area over which that we want to place a paver patio. Since we'll need to fill in the window well, I'm sure I'll have to remove the existing glass-block window. (I doubt those things are rated to with stand pressure.)
My question is: what size concrete block should I use to fill in the window opening? 8 x 8 or can I use something smaller like a 4 x 8?
Any other suggestions are welcomed.
Thanks!
Thanks!
Use a normal hollow concrete block the same thickness as your basement wall (usually 8", 10" or 12").
Height and length to fit the opening. don't be afraid to use a concrete brick (2 1/4 x 3 5/8 x 7 5/8) or any other soild size needed to fill.
You really don't have any pressure on the wall, but using a block the same thickness as the wall makes finishing easier.
Dick
Dick
Do I need rebars?
I'm planning to do the same. I need to seal a basement window for a raised patio.
After the glass window is removed, do I need to add rebars to the concrete blocks? Do I just use quickcrete to tie everything together?
Also, instead of having the raised patio resting on the side of the house, I'm planning to put up a conrete wall in between so the pressure will be against the concrete wall instead of the house. Is this a good plan? If so, do I still need to seal that basement window?
Thanks!!!
Thanks!!!
Hey:
First off, I'm in no position to answer a "should I" question. I'm a weekend hack who: 1. doesn't have a whole lot of money and 2. likes to do the work myself.
That out of the way, here's what I did. Knocked out old windows, spread a 1" layer of mortar to make an even bed, and put in 8"X16" block. I used a circular saw with a concrete blade to cut some blocks to size (and really tick-off my neighbors with all of the dust). After a couple of weeks, I layed on a thick cover of the water-proofing liquid tar. That's it.
I'm not sure if it was this forum or someplace else, but someone responded that I need not worry about ground pressure against the new block. Certainly blocking in a window does nothing to support the downward pressure of the house, since the window header takes care of this.
I hope this helps.
I hope this helps.
mchrist -
You did was necessary and you have structural problems to worry about. The window was only a hole in the wall that you had to fill.
congrats!!
Dick
congrats!!
Dick
