Leveling area under exterior door threshold
Old 09-13-05, 05:30 PM
dryflyangler
I recently built a oversized shed on an existing concrete slap that butts up to our concrete patio. The spot I have framed for the man door has unlevel concrete. There is just under 1/2" difference between one side to the other (of where the door threshold would be). Couldn't I use some type of concrete patch mix or leveler, build a little temp frame around where my door will set, put in the stuff and trowel it level, let it set and remove temp frame and now have a level spot for the door? Seems like it should work pretty well. Is there a better idea. I really don't want to chip out a big section or anything. Kind of seems like overkill for what I need.
Thanks all!
Old 09-14-05, 03:59 AM
C
shim?
What is the distance of fill you need from one side to the other? could you get a 2X6 (pressure treated or other size, rip it to shim and fasten it to the floor and install threshold to the top of it??
Old 09-14-05, 12:28 PM
dryflyangler
Nice idea. I will do some figuring and see which would work. Thanks!
