12.6 x 12.6 Concrete Slab for a Double Horse Wash Rack
What I need to know is:
(1) "How & What do I need" to prepare the ground before pouring the quickcrete?
(2) Any suggestions on what to use when mixing & pouring the quickcrete.
Any & all help will be greatly appreciated!
Thank you,
Barbara
I would rent or borrow a mixer. I don't think you could mix fast enough by hand, and even if you could 50 bags will wear you out.
Have as many friends as possible around for help. Once you start, you cannot stop unless you want to break the slab up into two smaller ones.
Just based on a quick calculation, your 4" slab will require about 7500# of material not including anything you will use for a base under it.
Dick
Dick
Check into havingthe concrete delivered. Even with a mixer and help, that is a lot of concrete to mix up. The first batch will be setting up before the last batch is done.
Using Dicks calculations, thats 94 bags of 80# bags. Way too many to do with a mixer.
What I need to know now is:
How do I prepare the ground Before pouring the slab?
