Film on pavers
Film on pavers
Help! I laid a field of concrete block pavers, sealed them with Thompsons Water seal and poured dry grout in the joints, and sprayed with water.
I still have a film that will not come off. Any suggestions?
Thanks
Tish
Thanks
Tish
Film on pavers
Just a guess - the film may have come from the dry grout. The natural process that occurs when water is added to cement in the formation of calcium salts that can be deposited on a surface. The Thompson's may have held this on the surface or prevented it from washing off (it is water soluable). The pavers could also contain the deposits, but they are not as fresh as the grout.
Fortunatedly, Thompsons doesn't last too long so the film should wear off.
I assume you applied Thompson's to get a desired appearance, since pavers do not need a coating for any other reason. If you want a coating, I would look at one of the coatings or sealers designed specifically for paver application. The supplier of the pavers could recommend a product (big boxes generally excluded from knowing what to with pavers).
Dick
Dick
Film on pavers
If they are decent pavers, it is unlikely the cement from the grout did not penetrate too well and it wear off, just as the Thompson's will.
Pavers have worked well for thousands of years. The dry grout is something new that is not needed with a good installation. Retailers like to push it for additional sales.
Dick
Dick
