Repair cracks on stucco walls
Old 09-30-05, 12:24 AM
sam zeigler
Somebody Please give me some advice to on how to repair a cracks lines on my stucco walls.
Thank you
Sam
Old 09-30-05, 07:08 AM
Received 786 Upvotes on 689 Posts
Welcome to the forums
The easiest way to fix minor cracks is with caulking. I usually caulk the crack and using a wet rag wipe the excess off the surrounding stucco. If it is a wide crack you can use some vinyl patch material - usually found in the masonary section of big box stores.
Old 10-02-05, 07:11 PM
B
Received 5 Upvotes on 4 Posts
Just wanted to chime in here... I just bought a 4yr old stucco home. the inspector noticed cracks and said that it needed to be repaired by a masonary professional. it sounds like its something you can "do it yourself"??
