Concrete Driveway Slab Leveling
Good day... Two of the slabs (7'X10') of my concrete driveway have shifted. Assuming the slabs are not reinforced, how risky would it be to use hydraulic jacks to lift one edge of each slab up to put sand under for leveling? I have considered mud-jacking but they want ~$200/hr (without warranty), which I'm resisting.
Without reinforcement, I would guess they would crack.
Mudjacking has a good history of success. Try to get another price to check the current market.
Dick
Dick
You never know with concrete cracking. The existing slabs could have any kind of concrete in them.
Cutting, jacking up, putting in sand, compacting and leveling is a lot of work. Then you have to get the 4 slabs to match and drain the way you want. If they crack, you will eventually have to get rid of the concrete and pour a new slab. Each 5 x 7 slab represents almost 2000 to load and haul away.
I question how can get the sand in, compact it and get the slabs to match and drain. I assume you want them corrected because they do not align and do not drain in the direction you want.
If the mudjacker has a good reputation and is experienced, I would talk to him to see what kind of time estimate you can get. Even if there is a crack in the mudjacked slab, it is supported uniformly and can still perform adeqautely for a long time.
Dick
Dick
