Can Grinding Masonry Cause Damage?
Old 10-05-05, 06:41 PM
nswider
I just hired someone to tuckpoint my building. He just started grinding out the masonry between the joints and I noticed that he has grinded into the brick pretty regularly to remove all the masonry. After thinking about it , it would be hard to grind out the masonry using a grinder without hitting the brick at all. Im afraid that there is a "finish" on the brick that once damaged can cause the brick to crumble, Even if the damage will be covered with masonry eventually. What are your thought on this?
Old 10-06-05, 06:43 PM
The Tuckpointer
It sounds like you have a fly by nite outfit working on your house.
