remove concrete form when?
Old 10-20-05, 07:48 AM
H
i just poured a footing for some extra back porch support, how long can i leave the form (tube) on the footing/in the ground before removing it or can it be left there indefiniteley?? thanks again all
Old 10-20-05, 08:01 AM
rdhamm's Avatar
Sonotube?
If it is a sonutube, leave it in the ground. you can cut off the top at ground level with a utility knife.
Old 10-20-05, 08:22 AM
H
sonotube?
the form is the one supplied at home depot stores called a quik-tube. sounds like they dont require being removed? i wanted to make sure they wouldnt help hold moisture or do anything else bad to the footing thanks
Old 10-20-05, 02:27 PM
rdhamm's Avatar
Yup that's it.
Leave it in. Cut the top off if you wish.
