clay brick wall
Old 11-14-05, 08:42 PM
Mike C.
clay brick wall
I'm new to brick but I have to build a clearance reduction wall for my coal stove. I selected clay brick and have found that the mortar dries up so fast that it does not adhere to the brick. Can someone give me some advice please?
Old 11-14-05, 08:52 PM
Received 1 Upvote on 1 Post
clay brick wall
What type of mortar are you using? - Is it a pre-proportioned mix with sand where you just add water. Does the mortar fall off before you can turn the brick and lay it or does the wall just not get stable soon enough?
Some clay brick are too hard (low absorption) and are hard to lay. The descriptive term would be "floating"
When you build with brick, you have be patient. The mortar takes time to cure since it is not like liquid nails.
Dick
Old 11-18-05, 08:47 PM
too dry
The bricks need to be wet before they are laid. Sounds like they are sucking all the water out of the mortar. Soft bricks will usually do that as hard bricks will not. Hope you use the right mortar.
Old 10-15-06, 02:17 PM
Dry Bricks
Wet the bricks.
