Adding a door
Old 12-15-05, 09:39 AM
shockenator80
Adding a door
I have a garage that I want to add an exterior door to allow my dogsa out into the back yard. Can a door be added to an exterior concrete block wall? If it can, is this a job better left to a professional and what type of contractor would I contact for this?
Old 12-15-05, 03:09 PM
Received 1 Upvote on 1 Post
Yes you can likely add it - be sure it won't affect structural integrity though. You may need an engineer to determine that. If the building is sound with the additional opening, it's a straightforward job - just hard work. A mason would do most of the work - possibly all if you can get them to set the door frame for you.
Good luck!
