crack in cement block
Old 01-27-06, 07:15 AM
C
My foundation is cement blocks. I noticed a small hair line crack. What is the best method for repair?
Old 01-28-06, 04:03 PM
Received 1 Upvote on 1 Post
Is the crack in the block or in a mortar joint?
How wide is it?
Is one side displaced relative to the other or is the surface smooth?
The repair (if any is done) depends on the cause, size and type (structural or otherwise).
If it is really a hairline crack and you have proper drainage and moisture control, you may not have to do anything.
Dick
Old 01-28-06, 09:29 PM
B
crack in foundation block
it could be caused by alot of reasons but seeing that it is just a hairline crack you could get fix-all cement patch from your hardware store but you must realize that its for cosmetic purposes.
Old 01-30-06, 04:56 AM
C
Crack is in Mortar Joint, very thin. I just don't want it to gt any worse. Chip it over or just mortar over it? If mortar, is there a specific type?
Thanks.
