Stucco vs. dirt question
Old 02-08-06, 10:05 AM
D
Question Stucco vs. dirt question
Our house was built in the early 60's. Dirt is up against the stucco exterior walls,thereby causing some cracking in the stucco. How bad can this be? What can be done to correct this? Thanks for any advice.
Old 02-08-06, 12:40 PM
Received 869 Upvotes on 760 Posts
Welcome to the forums
Is the stucco painted? Stucco always holds up better when it has a protecive coating. Depending on the size of the cracks, clean and caulk or restucco.
Old 02-08-06, 05:07 PM
Received 1 Upvote on 1 Post
The dirt is not causing the stucco to crack. You probably have poor drainage and the moisture (freeze/thaw or wet/dry cycles) is the cause.
Get rid of the excess moisture.
If the dirt is not well below the wood behind the stucco, you could have big problems down the road.
Dick
Old 02-09-06, 11:33 AM
D
Dick
We've got the dirt dug out away from the house about 6" deep & wide right now. If after we improve the drainage, repair/seal cracks, would it be better to fill in the trench with gravel rather than dirt? Thanks!
Old 02-09-06, 11:36 AM
Gravel would be much better than dirt. It does not hold the moisture and can dry out.
Dick
D
Old 02-09-06, 11:40 AM
D
Great info. I'll pass it on. Thanks!
