Ever heard of this?
Old 04-05-06, 04:01 PM
Received 1 Upvote on 1 Post
Question Ever heard of this?
I talked to some masons about building a foundation for a finished crawl space as an addition to our house. One went through everything he would do which included "two #4 bars in the footing tied to a ground wire". He would use wire reinforcing every other course, I believe grounded as well. He says that code now requires the grounding of the support metal due to potential lightning strikes.
Anyone ever heard of this?
Thanks guys!
Old 04-05-06, 05:11 PM
Ever heard of this?
Wire reinforcement every other or third course is just good construction practice.
I would question and intellegence or reasoning of someone that felt it had to be "grounded". What will he connect it with and how deep will be the copper grounding rod? - Sounds like someone that is confusing a few items.
I am involved in writing some code items and have not run across this application unless I am not reading the information correctly. Maybe he is referring to a multi-story steel structure.
Dick
Old 04-05-06, 05:56 PM
T
You don't ground reinforcing steel in concrete or horizontal reinforcing in CMU. Neither has contact with anything that would require it.
Old 04-05-06, 06:54 PM
T
Received 2 Upvotes on 2 Posts
Check with your local building code office. Codes often vary from area to area.
Old 04-05-06, 07:40 PM
T
Here is the theory:
http://www.psihq.com/iread/ufergrnd.htm
It is called "Ufer grounding". Check your code, as the man says.
