Control Joints for garage floor, how deep to cut?
Old 04-10-06, 10:15 AM
Hi all, I am new here, and with a new home will likely be spending alot of time here.
We had to pay our builder extra to have the garage floor slab cut. They didn't cut it however until a week after they poured it and it had already cracked in two places by then.
How deep should have have cut the concrete? I measured and they cut only 0.5 mm deep. I thought they were supposed to cut it alot deeper than that.
Thanks in advance.
Joe
Old 04-10-06, 11:02 AM
IHI's Avatar
IHI
IHI is offline
We've always cut 1/4" depth per inch thickness of slab. if it's only as deep as you say it doesn't really "show" the concrete where to crack/break at and will do little more than be a catch all for dirt and junk.
Old 04-10-06, 11:10 AM
That's what I thought, thanks....and that is all these cracks are doing is collecting dirt.
Joe
Old 04-10-06, 05:06 PM
Received 1 Upvote on 1 Post
Your saw cuts are not deep enough to be effective.
Since they were cut too late (same ady or next day). the cutting was harder and they did not spend the time to cur deep enough.
The later you cut, the deeper the cuts must be. Cutting after the cracks appear is just an ineffective show or attempt to do it the way it should be, but does not releive the builder of any responsibility.
Dick
