Refinishing exterior foundation wall (pic incl)
Old 04-25-06, 08:04 PM
Question Refinishing exterior foundation wall (pic incl)
Hello!
I am trying to refinish exterior foundation wall of my house. The wall was painted many many times before. See pictures:
http://bismarck.sdf1.org/house_front_1.jpg
http://bismarck.sdf1.org/house_front_2.jpg
I think there at least four layers of paint and other stuff. My wife and I spent a day unsuccessfully trying to clean up all that paint and material. While we were doing that; some of the cracks that were covered up before reappeared.
These are my questions:
1) Should I continue and try to clean all the paint and then:
a) plug the cracks and repaint?
b) stacco over it?
2) Should I just put another chicken wire up and stucco over it?
I think, I have to use the chicken wire approach in the back of the house anyway to cover up this mess:
http://bismarck.sdf1.org/house_back.jpg
Thank You!!
Oleg
Old 04-27-06, 05:59 AM
Unhappy
Pleeeaseee .
Share some advice with me.
I am hoping to start project this weekend and I still can't figure out how to proceed.
thank you!
Oleg
Old 04-27-06, 07:03 AM
T
After looking at the photos, this is what I would do:
Make sure that any remaining paint is adhered well.
Patch the cracks (I assume they are "dead", that is,not moving, since they were hidden) with a non shrink grout.
Paint the entire surface with a bonding agent designed for this purpose.
Apply fresh cement/sand mix directly to the surface in a 1/4" coat or less.
In the areas like behind the AC unit, I would skim it with the non shrink grout first.
Old 04-27-06, 08:00 AM
Thanks! This sounds like a plan!
Can I add something to concrete mix to make final surface white in color?
Can you give me an example of the bonding agent?
Old 04-27-06, 08:45 AM
T
I do not know if it is available in your area, but here white pre-mixed mortar is available. You do not want to use concrete; it has pebbles in it. Ask for glass block mortar if nothing else. White mortar is about twice as expensive as grey. Weld-crete is a widely available type of bonding agent.
Old 04-27-06, 12:59 PM
Received 1 Upvote on 1 Post
For an additive for bonding, there are many under different names. Almost all are latex because of the compatibility with other materials. In addidtion to Weld-crete, other names are Acryl 60(Thoro Products), Laticrete has a product and there are others.
To get white, the only way is to use a material containing white portland cement. Those with sand usually contain a natural silica sand or a white manufactured sand.
Dick
Old 04-27-06, 02:06 PM
T
An additive would help, too, but be sure that the bonding agent you use is capable of being painted on. Some will act as a bond-breaker. Make sure that it says "re-emulsifiable" on the label or lit. The reason I suggest the paint on is because of the existing paint; it will allow the underpinning to adhere.
Old 04-27-06, 03:47 PM
I am a little confused:
Do you mean the same thing when you say "bonding agent" and "additive for bonding". Is it still the same stuff I paint the surface with before applying the coat of cement?
Old 04-28-06, 04:04 PM
T
Yes, just be sure the bonding agent you apply as a coat is re-emulsifiable, and then it can be used for both. What that means is that if painted on and allowed to dry to a tacky/dry condition it will become soft with the wet concrete and provide a very good bond. Some bonding agents, those meant to be used as an additive alone, do NOT re-emulsify, and if you let them dry it forms a bond-breaker, i.e. no adhesion between the old and new.
Thorobond is an example of what you want, Acryl-60 is one you don't. Google those for comparative data.
