Rebar needed to fill trench?
Old 05-17-06, 12:14 PM
B
Using a concrete saw, I cut a 2'x6' trench in my concrete slab to replace the bathroom drains. Do I need to use rebar to when I pour the new concrete to secure it to the old?
Old 05-17-06, 01:06 PM
P
Not really, provided the fill in the trench that you're going to pour into is well compacted. However, it never hurts to err on the side of caution. A few pieces of bar dowelled into the sides of the old slab couldn't hurt anything.
Pecos
Old 05-18-06, 03:16 AM
B
And you probably had to excavate beneath the removed concrete for the plumbing. It's usually quite hard to compact this area sufficiently before you replace the concrete. Doweling should help the concrete bridge should you get settling of fill below newly poured floor.
bs5
Old 05-24-06, 02:08 PM
B
The trench is 2' x 6'. How long should the rebar pins be and what spacing should I use? Thanks for your input!
Old 05-25-06, 02:51 AM
P
Length... short enough to be placed into the drilled hole and pounded in, but long enough to stick out a few inches.
Spacing...every couple of feet, and staggered so the ones on one side fall between the ones on the other side. 3 per side would easily do it. Good luck.
Pecos
