driveway
Received 0 Votes
driveway
Trying to fix house for "quick sale". I have asphalt driveway with one crack that spreads width. Also live on busy street. I would like to improve appearance AND add side turn-around. Is bluestone the quickest and least expensive way to achieve both?
driveway
Bluestone would be worthless unless you have a good, thick, compacted base under it.
If you have to buy the bluestone, you would be better off to buy & install an interlocking concrete paver driveway area since it does not need as much of a base for the same strength driveway area.
The cheapest would probably be asphalt unless it is a small area, but still needs a compacted base under it.
Dick
Dick
