Filling Door Opening in Cinderblock wall
Old 05-30-06, 11:53 AM
T
I have a walk out basement where I doul like to close off a door opening. The opening is completely above grade. Do I want to fill in the opeing with Cinderblock. Or frame it in with studs and plywood?
Old 05-30-06, 12:27 PM
Received 1 Upvote on 1 Post
If you can lay block, filling with block the same thickness would be much easier with no problems of finishing between the different materials and thicknesses.
Dick
Old 05-30-06, 12:36 PM
T
How would that compare price wise? Also the wall is thicker than the blcok its self. On the inside there is drywall over the block.
Old 05-30-06, 12:53 PM
Costwise, nothing is cheaper than wood if you have to use sheetrock on the inside and match the block/firring/ sheet rock thickness. Then all you have to worry about is the exterior appearance.
More expensive, but the best match appearance-wise (interior and exterior) - Block (4" to 8" depending on the wall thickness), then 2x4 stud wall and sheet rock for the inside.
Dick
