Pool tile regrout
Old 08-22-06, 02:56 PM
C
Pool tile regrout
Need help with pool, please! We are regrouting our pool ourselves, but are getting conflicting information from several sources. Does all grout (even that in good shape) have to be removed from between tiles, or just roughed up? Is there a special "pool" grout, or will something designed for showers work? Thanks
Old 08-22-06, 03:41 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You can sand blast the pool or some do an Acid wash on it. Then re-marcited the pool . Any time I have had this done the tile is filled in with the marcite. Its all the same mix . Just a little more fine sand in it. Most use the new marcite with the marble chips in it . That last a lot longer .
ED
