Anchor PT Lumber to Slab
Old 10-11-06, 06:32 PM
E
I am going to be removing an exterior door and framing a wall in place of it. I am thinking of using tapcon screws to anchor the PT lumber to the slab.
How deep to the tapcon screws need to be in the concrete? What size screws should I get? IS the tapcon screw the best option considering this is a load-bearing exterior wall?
Thanks...
Old 01-22-08, 08:44 AM
A
Tapcon installation
There is a full tapcon installation video on www.confast.com
Thanks...
Old 01-24-08, 04:55 AM
A
Thanks...
A tapcon screw has to go into the concrete at least 1 inch but no more than 1 3/4 inch. If you try to embed the screw any deeper the lead threads will wear down, stop cutting the concrete and then the head will break off of the screw.
