chimney crown repair
Old 11-15-06, 11:43 AM
Andy Beet
Hi,
I have 2 terracotta type flue's protruding from my chimney (one for the fireplace and the other for the central heating system). I am located in massachusetts.
The two flues are about 1 inch apart. In the gap between them where they meet the crown, no mortar exists. So there is about a 1 inch by 8 inch opening in the crown of my chimney in between the two flues.
How should i fix this? Any help would be greatly appreciated, especially as the cold months near.
thanks
Andy
Old 11-15-06, 11:11 PM
Frank99's Avatar
Mix 1 portland cement and 2 parts sand and water just enough to make it like peanut butter, and fill in the crack, you can use a stick to push it in and smooth it out.
Frank
Old 11-15-06, 11:17 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
You want to build it up a little higher there with the new cement . So any rain water runs out of there.
Old 11-16-06, 07:59 AM
Andy Beet
thanks guys. i'll do that.
I do have a question though. It seems like the gap is maybe a little large and i fear that the cement will just fall down the gap. Can i bridge the gap with something then cement over that?
cheers
and thanks for the quick response
Andy
Old 11-16-06, 08:38 AM
Ed Imeduc's Avatar
Wink
You could like jam some fiberglass insulation down in it some. Then cement over it
