Concrete to Metal
Old 01-19-07, 02:31 PM
G
Question Concrete to Metal
What is the best way to secure metal against concrete? I'm using brass strips between concrete "tiles", should I just trust the weight of the concrete or use some type of epoxy. If epoxy, what do your recommend?
Old 01-20-07, 06:27 AM
What concrete product, what application and to what metal?
Old 01-25-07, 11:10 AM
G
Question
Quikrete 5000 with acrylic fortifier. Brass metal around the rim of a concrete shelf.
Old 01-25-07, 08:02 PM
T
Technically, you do not want a bond between the metal and the concrete, since such a bond will most likely cause the concrete to spall at the joint. A bond breaker would be more appropriate.
Old 01-26-07, 01:09 PM
G
Question
I'm not sure I follow that, are you saying you cannot attach metal to concrete with an adhesive?
Old 01-26-07, 01:19 PM
T
No, you can, the problem is that metal and concrete have different thermal characteristics, and since the concrete has a lower tensile strength than the metal, it could spall the concrete.
